Anyone Installed And Engine Oil Cooler System?
After reading this thread http://www.gm-trucks.com/forums/index.php?showtopic=101852 I am curious if anyone has purchased the lines, cooler etc in order to have oil cooling capabilities?
I will say I was somewhat disappointed my new SLT with the 5.3 didn't come with it, my old 97 Sierra did and I always liked knowing I had it.
With the adaptor plate already in place, I am sure some lines can be purchased already pre-bent to lenght etc, just curious how much of a chore it would be to install it?
Is there anything that will be in the way, will it be a direct bolt on etc and lastly, do any of you think it is necessary?
I don't think it would hurt having it but does it do enough to justify having it?
I don't see why you couldn't add it,but you'd also have to buy another radiator.
Good point, I didn't think of that, I was just thinking of an auxillary type cooler like a tranny cooler.
I assume if such a system exists, it would have it's drawbacks? I also assume the engine oil has to be kept at a certain temp rather than as cool as possible?
I had thought of buying the kit with the pipes and putting a Hayden cooler on there, I forget which one but it's a lot smaller than the 679 for the radiator.
First I'm going to get my Aeroforce Interceptor gauges and a temperature sensor and monitor the temperature to see if it's needed.
After I got the gauges and saw the temps, I would monitor pre and post cooler install to see if the temperature got too low, if so, I'd just add a thermostat.
My problem is, where to install said sensor.
You can look at this PDF at the Hayden website. Look on about page 69 or 70. They have a thermostatic bypass valve that you would want to install to keep your oil temp from dropping too low.
They also have a temp sensor.
The oil pressure idiot light or oil pressure gauge sending unit is in the side of the block. You could simply thread a T-fittting in it at that point and add the extra sending unit your wanting to install. hence thats what I did. Use teflon tape to insure no leaks in the future.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 328 Guests (See full list)
