How To Lower Transfercase 1/2"?
I need just a little more clearance (about 1/2") to the floor sheet metal at the front drive shaft transfer case location.
Would it be advisable to lower the trans support to tilt the drivetrain down in back to this degree? Or is there a method to lower all 3 drivetrain supports the 1/2" needed?
I have no concern of alignment for the front drive shaft as.
Thanks
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
