Oil Drain Plug Washer
I did a search but wasn't able to find it. My '05 GMC Sierra, 4.3, has a drippy oil drain plug. My guess is that when the oil was last changed a new washer wasn't installed. Anyone know the size and material I want to have? I've seen plastic ones and aluminum ones. Not sure which is better but I know that a 5 year old anything shouldn't be leaking at all.
Thanks.
Why not just buy a new bolt? I'm sure it will come with a washer, shouldnt be too expensive. Can probably get it at any auto parts store.
According to the Advance Auto website you need Motormite part number 66451, $2.19. It looks just like the rubber gasket that the drain plug in my '96 Blazer uses. I wouldn't use the white plastic (nylon maybe??) gaskets. I did, and it leaked. Since I put the rubber one on, it's been good.
Here's a pic:
That's the thing, every Pre-2000 car I've ever owned has never used any kind of washer at the oil drain bolt. My wife's Accord needs a new crush washer every time you replace the bolt or it leaks, and I thought this was like that, too. Either way it's leaking and there's nothing wrong with the bolt that's in there. Looks just like the ones that Advance shows on their site- the Motormite bolt. I'd always heard that oil breaks down rubber so I wasn't sure that this rubber gasket would last. I'll give it a shot, though. Might grab a magnetic plug while I'm at it.
Thanks.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,168 Guests (See full list)
