HEATHN Posted September 17, 2009 Posted September 17, 2009 I have a 2008 chevy suburban w/ the 5.4L V8. I is way under powered for pulling light loads. I was wondering if the basic bolts-ons (filter, exhaust, programmer) are worth the price to performance gains. It feels like the power is there, it just needs to be unchocked.
Stevens03 Posted September 17, 2009 Posted September 17, 2009 Well that Ford 5.4 motors your problem... Get a GM 5.3 in there and you'll be fine. If thats not an option, If it was me, I'd look at a gear swap and custom tune to get you some more low end grunt. What gears do you have now? A cam swap would give you some more power for that heavy SUV. The basic bolt ons will help a little, but I don't think enough to justify the cost. Custom tune at the very least.
HEATHN Posted September 21, 2009 Author Posted September 21, 2009 I have a 3.73 gear rearend. Any suggestions on a custom tune.
Toadz Posted October 4, 2009 Posted October 4, 2009 Try a custom tune with Justin at Black Bear Performance first. If you're still wanting more after that then I would look into cams and exhaust.
hivoltg Posted October 21, 2009 Posted October 21, 2009 What would be a good cam to run in my 04 5.3? I'd like to have more low end grunt and more towing power. Would the suggested cam have a differnt sound that the stock one or is it pretty mild?
wlvrn1215 Posted October 21, 2009 Posted October 21, 2009 I have a 2008 chevy suburban w/ the 5.4L V8. I is way under powered for pulling light loads. I was wondering if the basic bolts-ons (filter, exhaust, programmer) are worth the price to performance gains. It feels like the power is there, it just needs to be unchocked. underpowered for light loads??? There must be something wrong with your truck then. I pull 6k without any problems. Even stock 4k wasnt an issue.
birdiemaker Posted January 30, 2010 Posted January 30, 2010 Are you switching the transmission to "Tow Mode?" It makes a difference in the shift points. I had to learn to do that when they stopped making manual transmissions. Mine feels weak just driving it around, but it actually tows okay.
