F/s- Programmer And Ecm/tcm Modules
Erichcb
Below for sale is a Superchips flashpaq programmer that was used for 8 months (sorry no box) This programmer can be for any 2007+ (NBS) with 4.8L,5.3L or 6.0L engines. Paid $350.00 and I'm selling it for $200.00 OR BEST OFFER
If you are looking for a extra set of modules (ECM & TCM) here is a good deal for you I'm selling both for $100.00
Both are in box's and ready to ship...OHH...did I mention FREE SHIPPING!!!
SOLD!!!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
