2007 Tire Pressure Sensors
I have a new body 07 1500 crew ltz with tire psi monitor, i can buy a set of oem 20" wheels off a 2006 crew ltz, what will i need to do to have the tire psi work, can i remove the sensors from my oem 18", i am unsure if the other wheels had the monitor in the truck, i am actually trading mine for them, the guy wants a more aggressive tire then the 20" has available. how do i remove the sensors i have now if i can re use them. Please only answer with known accurate information...PLEASE!! Thanx Tom
how do they come out? will they fit any wheel, I can get them removed before we trade but how will i know if they will fit the 20's ,the 20's are oem gm wheels but from an 2006. Do they fit any wheel? I looked at the parts list it appears they are connected to the valve stem, so the tires will need to be broke down. thanx again
The sensors from your OE 18's will work,You will however have to buy new valve stems,The tires won't need to be "broken down" the entire way around the wheel,just enough to get the sensors out.
You are correct in that the sensors are connected to the valve stem.
If you go on ebay, you can buy a full set with new stems and sensors for less the $100 if you shop around. I paid $75 for 4 new sensors in GM bags. There are other sources that have aftermarket sensors of quality maker for about $26 each. There are a lot of used sensors on ebay. I'd avoid a used sensor just because of the unknown battery life.
As Rich pointed out, you should replace the stems, even if you use the old sensor. They disasemble with a screw in the center of the backside of the stem. Keep in mind that the "sensors" are really transmitters as well. They work on Bluetooth transmitter/reciever technology. There is a lithium battery in each "sensor" and that will eventually go dead. I don't know how long the battery will last. But GM recommends the sensors be replaced at each tire change. They'll probably go at least twice the average tire life. But if they die earlier, what the heck, it just gives you a TPMS message. No biggie.
Actually Chuck GM recommends that you change the valve stem when the sensor is removed from the wheel,not the sensor itself,the sensors are designed to last 10 years or 150,000 miles.
Heres some helpful information.....
#07-03-16-004B: TPM System Overview, Diagnosing Tire Pressure Monitor System (TPM) Concerns and TPM Frequently Asked Questions (FAQ) - (Mar 26, 2009)
Subject: TPM System Overview, Diagnosing Tire Pressure Monitor System (TPM) Concerns and TPM Frequently Asked Questions (FAQ)
Models: 2007 Buick Lucerne, Rainier
2006-2007 Cadillac DTS, Escalade Models
2007 Cadillac SRX
2006-2007 Chevrolet Avalanche, Impala, Monte Carlo, Suburban, Tahoe
2007 Chevrolet Equinox, Silverado, TrailBlazer
2006-2007 GMC Yukon Models
2007 GMC Acadia, Envoy, Sierra
2007 Pontiac Torrent
2007 Saturn AURA, OUTLOOK
2007-2009 Saab 9-7X
2008-2010 GM Passenger Cars and Trucks (including Saturn except ASTRA)
2008-2010 HUMMER H2, H3
Attention: The information found in this bulletin is designed to be a single source for the majority of questions you may have about the Tire Pressure Monitoring (TPM) Systems found on General Motors Vehicles. While comprehensive, the bulletin is divided into sections, so after reviewing the whole document, you can reference just the section you need when further questions arise. A copy of this information may also be given to your customer as the "FAQs" section is written to assist you in explaining the most common misconceptions about the system in an easy to understand way. This bulletin does not apply to the Saturn Astra and does not apply to vehicles in Canada that are not equipped with Tire Pressure Monitoring.
Customer Concerns and Confusion
When a customer comments on a condition related to tire pressure monitoring, it is very important to distinguish between Check Tire Pressure / Low Tire Pressure conditions and Service Tire Monitor system issues. Understanding the difference between the two distinct conditions will help you distinguish between normal system operation (tire needs air) and a system malfunction.
There are two important differences between a Check Tire Pressure / Low Tire Pressure message/light and a Service Tire Monitor message light:
• A Check Tire Pressure / Low Tire Pressure message/light will stay on solid and no system codes are set. The TPM system is operating as designed. Correcting the tire pressure will resolve the issue.
• A Service Tire Monitor message/light will blink and system codes WILL set. There is a condition that should be diagnosed and corrected.
Service Tire Monitor System (light blinks, then stays on)
The Tire Pressure Light will blink for about one minute and a Service Tire Monitor message will be displayed when a system malfunction occurs. For example: If one or more tire pressure sensors does not transmit information for 18 minutes of driving, the TPM system WILL set a code, display a message, and BLINK the light for about a minute, after which the light will stay on solid for the remainder of the ignition cycle. If the system fault is intermittent, the message/light may also be intermittent - on during some ignition cycles, off during others.
Low Tire Pressure Warning (light stays on solid)
If the TPM system detects a tire pressure below the threshold, the Check Tire Pressure message and the Tire Pressure Light will come on and stay on. The message and light may be intermittent in nature, especially during cold weather.
Conditions That Will Cause the Low Tire Pressure Warning Message/Light to Display:
• The tire may have picked up a road hazard and/or have a slow leak.
• The tire pressure may not have been checked in the past six months.
• The air pressure in a cold tire may be at the pressure where the system is required to warn the driver. However, that same tire will rise in temperature and pressure as the customer drives, causing the message and light to go out.
• The tires may have been rotated, pressures adjusted, and the new tire positions were NOT re-learned into the vehicle. This can occur on vehicles that have two different placard pressures for front and rear tires.
• There may be a slow leak in one of the wheel and tire assemblies (Valve Stem, Wheel Rim, or Aluminum Wheel Porosity Leak). If this condition is found, please refer to bulletin:
• #05-03-10-003B - Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant)
• #04-03-10-001C - Info - Tire Puncture Repair Procedures for all Cars and Light Duty Trucks
The Effect of Outside Temperatures on Tire Pressures
Important: As a rule of thumb, tire pressure will change about 7 kPa (1 psi) for every 6°C (10°F) decrease in temperature - dropping when it gets colder outside, rising when it gets warmer.
Tire pressure should be set to the specified placard pressure at the lowest seasonal temperature the vehicle will encounter during operation.
The correct action to avoid a Check Tire Pressure message due to extreme temperature changes is to do the following:
• Use an accurate, high quality tire pressure gauge.
• Re-learn the TPM sensors and adjust the tire pressure to the placard values after every tire rotation.
• Let the vehicle sit and adjust the tire pressure to the specified value when the tire temperature is at the lowest expected temperature.
• Never set the tire pressure below the placard value regardless of tire temperature or ambient temperature.
Important: On extremely cold days, if setting the tire pressure when the vehicle has been indoors, it may be necessary to compensate for the low outside temperature by adding 21-27 kPa (3-4 psi) more than the placard pressure. At some later time, when convenient and when the tires are cold (outdoors), the pressure should be re-checked and adjusted to the placard pressures if necessary.
Using the TPM Tool
TPM Tool J 46079 Software Updates and Hardware Update Kit
The J 46079 TPM tool is a valuable aid in diagnosing system faults with TPM systems. It is a software-driven tool that REQUIRES periodic updates in order to work on new model cars and trucks. Failure to update the tool with the latest software version may result in possible misdiagnosis.
TPM Software Version 3.5 has recently been shipped to each GM dealership in the J 46079-30 TPM update kit. All future TPM software updates will be posted in GM DealerWorld (U.S) or the GMinfoNET (Canada) as needed. Under the Support tab, access "TPM Downloads."
This update consists of two parts:
• A hardware update kit that consists of a custom rechargeable battery pack, battery cover with charging terminals, and a charging cradle with a smart charger where the whole tool will fit into the cradle for charging (same concept as a cordless phone). This hardware update substantially increases the life of the batteries and will assure that the TPM Tester always has full battery capacity.
• The software update will add new vehicles and also improve the speed of the tool's read-back ability and accuracy.
Sensor transmission signal strength is displayed in the upper left corner of the main display next to the tool's battery level display. When the tool is used in both activate or scan mode, it will receive the sensor's transmission and indicate its signal strength. It is important to note the sensor's transmission signal strength since it is a good indication of an accurate diagnostic.
TPM Tool J 46079 User Tips
Diagnostic Tip
The placement of the TPM Tester's antenna when activating a sensor is critical, especially with the latest software update. When activating a sensor, the antenna tip of the TPM Test J 46079 must be placed on the sidewall, perpendicular to the tire, and close to the valve stem (see photo above). This will assure proper activation of the sensor. If the antenna of the TPM Tester is placed either on the valve stem or on the wheel itself, the tool may not properly activate the sensor, causing improper diagnosis.
Diagnostic Tip
If you encounter a sensor that does not respond when activated by the tool, try activating another sensor that responded previously. This will help you determine if the tool is able to activate the sensor or if you have a problem with one particular sensor.
Diagnostic Tip
When using the tool during a sensor learn procedure, use the "Activate" soft key on the tool. Press the key for one second then release and the tool will perform an LF (low frequency - 125 kHz) activation cycle. You do not have to hold the key until the vehicle acknowledges. Holding the key will just reduce battery life. The LF activation of the sensors wakes them up and forces them to transmit their IDs immediately. This allows a much shorter sensor learn procedure than using the Delta P method.
TPM Frequently Asked Questions (FAQs)
The following are some of the most asked questions:
Q: What is a Tire Pressure Monitoring System?
A: The TPM system consists of four sensors (one in each wheel), which transmit wireless (RF) signals to a vehicle receiver (typically, the same receiver that performs the keyless entry function), the Low Tire telltale, and the Driver Information Center (if equipped).
Q: Do all Vehicles Have Tire Pressure Monitoring?
A: Starting with the 2008 MY, all GM vehicles sold in the United States are equipped with tire pressure monitoring, to meet the mandates of FMVSS 138. Some vehicles built prior to the 2008 model year or sold in Canada have tire pressure monitoring; check vehicle build and RPO information to be sure.
Q: What does the Low Tire Telltale Look Like?
A: The Low Tire telltale is a yellow telltale that looks like an exclamation point inside of a horseshoe:
Q: When does the Low Tire Telltale Come On?
A: The Low Tire telltale MUST come on when a tire's pressure drops to 75% of the Recommended Cold Inflation pressure (the pressure value printed on the vehicle placard - the yellow and white sticker in the driver door opening.)
There are several events that may cause a Low Tire warning:
• On vehicles where a different placard pressure is required between the front and the rear axles, the tires may have been rotated, pressures adjusted, and the new tire positions were NOT re-learned into the vehicle.
Q: What does the TPMS Malfunction Warning Look Like?
A: The TPMS Malfunction indicator uses the same telltale as the Low Tire warning. The telltale will flash for the first 60 seconds of a KEY ON event, and then go on solid.
Q: How can I tell the difference between a Low Tire and a system malfunction?
A:
• A Low Tire telltale will be on solid immediately after KEY ON, and will be accompanied by a CHECK TIRE PRESSURE message in the Driver Information Center (if equipped).
• A system malfunction causes the telltale to flash for the first 60 seconds of a KEY ON event, and then go solid.
Tip
These behaviors repeat at each KEY ON cycle. The best way to diagnose the vehicle (if you're not sure which warning is being displayed) is to KEY OFF and KEY ON again while watching the telltale and DIC messages.
Q: When are Diagnostic Trouble Codes Reported?
A: DTC's are reported ONLY when there is a system malfunction (flashing telltale). When a Low Tire (solid telltale) is displayed, that means that the system is working exactly as it's designed to do - since there's no malfunction, there is no need for a DTC.
Q: What service is needed if the Low Tire telltale is on?
A: When a vehicle comes in with a Low Tire warning, the tires should be checked for any leaks or damage (from road hazards). After those have been repaired (or if none are found), the tires should be inflated to the pressure shown on the Vehicle Placard - the yellow and white sticker in the driver door opening. It is not necessary to relearn the sensors after correcting the pressure.
Q: Can Tire Pressure Monitoring be turned off?
A: Tire Pressure Monitoring is now a mandated safety system in the United States and cannot knowingly be disabled by an OEM nor an aftermarket service provider (49 USC 30101).
Q: Can the Tire Type and/or Placard Value be changed, if aftermarket tires or wheels are installed?
A: The Tire Type (P Metric, LT Load Range C/D/E) and the Placard Value (Front Placard and Rear Placard, individually) are stored in the receiver as calibrations and CAN be revised at a GM Dealership with a Tech 2. (The RCDLR Setup screens allow this.) Since the under-inflation threshold is calculated as a percentage of the placard; correcting the placard values when different tires are installed will bring the vehicle back into compliance.
Q: What is Sensor Learning (Sensor Re-Learning, Sensor Training, Sensor Matching)?
A: Each sensor has its own unique identification code (ID) that is transmitted as part of its wireless signal. The receiver stores and uses these IDs to determine which sensors are installed on the vehicle, and in which corner of the vehicle the sensor resides in (so that both the pressure information provided in the Driver Information Center and the diagnostics are correct). Sensor Learning is the process that puts sensor ID information into the receiver.
Q: When is Sensor Learning required?
A: Sensor Learning should be done when the vehicle's tires are rotated (since sensor position on the vehicle has changed) or when a sensor is replaced/a new sensor is installed (since a new ID has been introduced to the vehicle). Sensor Learning is not required when simply correcting the tire pressure resolves the vehicle problem.
Q: Why are dashes (" - - "), or a pressure value of 148 PSI (1020 kPa), sometimes displayed after a battery disconnect?
A: These displays come up after a battery disconnect/reconnect because the system is waiting for updated pressure information to be sent from the tire pressure sensors. As each sensor transmits its information, the display is updated appropriately. Note that when dashes or 148 PSI (1020 kPa) are displayed after a battery disconnect/reconnect, the System Malfunction warning is NOT displayed - because the system is still working properly, and simply waiting for updated information from the sensors. Driving the vehicle above 20 mph (32 km/h) for 2 minutes gets the sensors talking, and restores the correct pressure values to the display. It is also possible to restore the values by using the J-46079 TPM tool, using the "Activate" function at each tire to activate the sensor (it is NOT necessary to put the system into Learn mode, in this special case).
Q: Is there a sensor installed in the spare tire?
A: No - a sensor is not installed in the spare tire.
Q: Are all of the sensors the same?
A: All of the sensors are not the same. They are supplied by different manufacturers, and send different RF signals to the vehicle. SOME of the sensors are interchangeable, though - while they may look different, they DO send the same RF signal to the vehicle and MAY be used in place of one another on a vehicle. See the Sensor Information Guide for more details about which parts are interchangeable.
Q: What size is the sensor nut?
A: The sensor uses an 11 mm hex nut for attachment.
Q: Will a tire pressure sensor fit in every wheel?
A: GM wheels (including Accessory Wheels available from GM SPO) are designed to accommodate tire pressure sensors. Many aftermarket wheels also accommodate tire pressure sensors, but not all do. In some, the valve stem hole is placed in such a way (pointing straight into the middle of the wheel, for example) that the motion detection components inside the sensor will not work correctly.
Q: Can the valve core be replaced?
A: The valve core can and should be replaced if it is removed from the sensor, but the replacement part depends on the material of the valve stem (Refer to Service Bulletin # 08-03-10-005).. Sensors with a rubber valve stem may use a standard brass valve core for replacement. Sensors with an aluminum valve stem CANNOT use a brass core; instead, they require a nickel-plated valve core to protect against the corrosion that forms when dissimilar metals come in contact. See the service parts guide for the correct GM part numbers to order and use.
Q: Can the grommet (and washer) be replaced?
A: The grommet (and washer) can and should be replaced if the sensor is removed from the wheel. The rubber grommet provides the air seal in the valve stem opening, and a new one should be used to ensure a fresh seal after each service. See the service parts guide for the correct GM part numbers to order and use.
Q: Can the rubber valve stem be replaced by itself?
A: The rubber valve stem is attached to the sensor electronics by a TORX screw. The valve can and should be replaced whenever the sensor is removed from the wheel. See the service parts guide for the correct GM part numbers to use.
Q: Can the sensor be cleaned with a sharp pin?
A: NEVER use a sharp object to clean the pressure port of the sensor; it can be damaged and lead to part failure. If the dirt/grime/obstruction cannot be removed with a cloth, replace the sensor.
Q: How long will the sensor's battery work?
A: The sensor is designed to last for 10 years or 150,000 miles (240,000 kilometers).
Q: Are tire pressure sensors compatible with aftermarket tire sealants?
A: Tire pressure sensors are not compatible with commercially-available tire sealants. Tire sealant materials can clog the pressure port of the sensor, and lead to inaccurate pressure readings and improper Low Tire warnings. Additionally, some sealant products use materials that can degrade the protective potting material that covers the sensor's electronics.
Q: Are tire pressure sensors compatible with GM Inflator Kits?
A: While tire pressure sensors are NOT compatible with commercially-available sealants, they HAVE been tested and ARE compatible with GM Inflator Kits and the sealant that they use. After inflator kit use, the sensor should be inspected for any damage, and replaced/cleaned as needed.
Q: Are tire pressure sensors compatible with nitrogen inflation?
A: Tire pressure sensors are compatible with nitrogen inflation (normal air is already 78% nitrogen).
Q: How do changing outside temperatures affect tire pressure?
A: All gases change pressure as their temperature changes, and air or nitrogen are no exceptions. A good rule of thumb is that tire pressure will change by about 1 psi (7 kPa) when temperature changes by 10° F (6°C). Customers may experience this as temperatures change from summer to fall and into winter - tire pressures will drop as the outside temperature gets colder. Customers may also experience this as temperatures change between mid-day and overnight.
Q: How should tire pressures be set at PDI?
A: Tire pressure should be set to the specified placard pressure at the lowest seasonal temperature the vehicle will see during operation. The correct action to avoid a CHECK TIRE PRESSURE message due to extreme temperature changes is to: Use an accurate high quality tire pressure gauge. Let the vehicle sit and adjust tire pressure to the specified value when tire temperature is at the lowest expected temperature. Never set tire pressure below the placard value regardless of tire temperature or ambient temperature On extremely cold days, if setting tire pressure when the vehicle has been indoors, it may be necessary to compensate for the low external temperature by adding 3-4 psi (21-27 kPa) more than the placard pressure. When convenient, at some later time, when the tires are cold (outdoors), the pressure should be re-checked and adjusted to placard if necessary.
Thank you for the help. With the sensors being that cheap seems smart to not worry about saving them, may cost as much to have them removed. The 20's need tires any way, so may as well wait until I replace the tires and just do the new sensors instead of worrying about that now.
Thank you to everyone who replied, thanx Rich for time in my messages. I just figured out the pic in the sig will change to truck when i get a minute, going to bed now.
Rich,
thanks for the straight scoop on the battery life.
A question for you: I just put load range E tires on my 1500 and just tonight, recalibrated the TPMS. I have 50 psi in the tires now. The DIC shows a message to check the tire pressure upon starting the truck. If I push any button it changes the display to the next selection and all is normal. The DIC shows the accurate tire pressures. Evidently, there is a "high pressure" threshold in TPMS. Is this something that can be recalibrated to a higher (80 psi) threshold?
I "think" you can recalibrate it higher,I'd have to check with one of the techs. though
I'm looking for the sensor part # for my 04 Denali, does anyone have this info or can you direct me to a site where I can look it up? thanks.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 385 Guests (See full list)
