Rfi?
Anyone else get RFI? If I turn the sound down on my radio(Factory radio) and speed up, I can hear it through my radio (like an old car with a bad condenser or solid wires). It's been doing forever,but lately it really seems to bother me more.Any ideas where to look?
I get it alot with my system, but know whats causing it. Always had it.. I use an old kenwood parametric eq with my system, and the postive wire along with something that went bad inside the eq is causing this noise. I only hear it if volume is on low, once I turn it up the noise is gone, or shall I say covered up.
With your factory radio, I would say check out your antenna and make sure it is securely in the radio. If it was removed before, the antenna might not have been fully inserted and the wires might be touching the metal causeing interfere. If you never removed the radio before, then I would still check it out and make sure everything is the way it's suppose to be back there. It's very easy to remove the radio. Noticed in your sig you also have a plow on the truck. Who did the install? Cause a not so good install could also affect interfernce on occassions.
you may have alternator whine. There may be a ground issue somewhere. You can get ground loop isolators that will eliminate that but I am not sure how to do it on a factory radio. Check any grounds on your truck and behind the radio.
I do have a plow and it's hooked up the right way (isolation module etc...). But it still made the noise before I installed anything. My only concern is if the radio is picking it up, I'm guessing the computer and the rest of the truck is too
Don't think it's anything to worry about. There is so much RFI around you it isn't funny.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
