Rear Door Speaker Is Not Functioning
So I noticed this weekend that my rear passenger speaker on my '07 Avalanche is not functioning. Before purchasing new speakers I want to make sure it isn't just a loose connection. I have removed door panels in the past but not on my '07. Is there anything I need to know? Any tips, tricks, tools I should know about?
Thanks.
There are two bolts behind the door handle and one bolt behind the door opener lever. On door lock that goes up or down by the window there is alittle box looking thing that you pop out with a screw driver and it comes off. Then pop the clips around the sides and bottom and pull the door panel up.
The speakers are crap. I had one on mine that shorted out and half the time didnt play at all. A few other people have had speakers not working too. I wiggled the connector many times and it didnt help. I replaced all my speakers with Infinity and have not had a problem since. It sounds alot better now with tweeters in the back too.
Thanks! I know the speakers are crap and I would LOVE to replace them but I just don't have the funds right now. Hopefully it is a loose connection and I can fix it for now. Otherwise I may just have to live without for awhile.
  • 1 month later...
My rear door speaker hasnt worked for months now in my 07 nbs sierra, today I replaced both rears with pioneer replacements, and still nothing, if I fade the speakers specifically to that speaker, if I put my ear up tight to it, I can faintly hear the music.....any ideas?
This is what I'm worried about as well. I haven't had the time to remove the door panel to check my speaker that is out. However, I did notice that my other rear door speaker is starting to put out less and less sound (getting quieter). I'm beginning to wonder if this is a head unit issue and not speakers. Anyone know how to figure it out?
Something about those rear door speakers. In my HD CC the rear driver's speaker did not work. I bought 4 infinity's and that same side still doesnt work. Of course i didnt notice it till i had everything buttoned up. First thing i'll do is swap the speaker to rule that out and go from there.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
