2009 Ec Lb
I just bought a 2009 1500 Extended Cab Long Box with a 5.3 in it. I am trying to find a cat-back exhaust for this truck. I can not find a company that makes this exhaust. Can anyone help me out.
Thank you.
Brad and Mike
Check this out from Flowmaster part number 17439. Granted I have a 07, but it might work on the 09"s. I like it by the way!
Stanz
07-08 catbacks will not fit 09s without modification. You must cut the front flange off the catback and have it welded to the slip-fit connection after the third cat that the 09s have. If you plan on putting headers on, you have to get a set of 07-08 headers and Y-pipe, then an 07-08 catback will bolt right up. That is what I did.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
