2009 Silverado Problem
ok i just bought a new 2009 silverado crew cab xfe model. my truck has 550 miles, i was driving it yesterday and it just shut off on me at a red light and wouldn't start.. let it sit for couple mins and then it fired right up but the check engine light stayed on so i had it towed to my nearest chevy service center.. turns out the ECM has gone out, and just wondering if anyone is having the same problem im having. dealership doesn't know what caused it, but they are replacing my ecm seems strange that it has gone out so fast, truck is brand new with no mods all stock. oh also i saw something on my info display under my tach that said something about reduced power didn't really get a chance to look at it very good since i was trying to coast off the road as safely as possilbe. anyways any help or info would be great. thanks for reading my little story. hope this doesn't happen again. but will try to keep you guys posted on what happens when they replace my ecm, will be pick up my truck on monday hopefully.
Truck went into fail safe mode. Caa caa happens. It's probably just a fluke. It will run great I'm sure. Get any bugs worked out now. All the ones that I have owned have been trouble free for many years!
Trucks are run by computers now. Electrical/Electronic problems must be expected sooner.. or later.. Just like buying a new expensive HD TV or Computer, sometimes when you open it up out of the box something is wrong :jester:
At that low mileage I would just call it a fluke. My 07 had 32k and my 09 now has 7k and never had a problem. It happens once in a while. I think everything will be alright.
Mike
Just a freak occurrence. I've never seen anybody in here have that problem... and that covers a lot of GMT900 owners. I'd bet on a one time part failure and that it never happens again. Just the same, it does suck to have something happen to your brand new truck.
Hope they solve it right away for ya.
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
