Need A Crank Re-learn
I need to get a crank re-learn done. I have been to a few shops in my area with no luck. One place was like 2 weeks out. Forget that. What kind of service is that. I know it only takes like 5 min. tops. Another guy I went to was a friend of a friend. He told me I need to flash the the pcm and needed to go to the dealer. So he clearly didnt know what I was talking about. Also had to much work to be able to do it. Now if im understanding it right you its only a matter of connecting it up to the computer and going through a couple steps. why cant a shop just have some kid do it while he is changing oil. Just makes no sense why no one wants to help anyone these days. I dont really want to go to the dealer. That would be my last resort. They arent really friendly around here and are pretty much crooks.
Is there anyone around the nashua NH area that can do it or know someone that can help me out. Hp tuners? or another handheld that is capable. Or tech II
I dont have a check engine light for it yet. Why isn't it on if it needs to be done?
Have you tried calling around to mechanics? Just ask if they have a Tech II or similar, if they say yes, tell them you would like a crank relearn and that you know the procedure. It honestly is just 45 secs to complete.
I have an OTC Genisys scan tool and it will do the crank relearn procedure. If you can't get access to a scan tool with the capability, try an independent shop. It's a ten minute procedure.
If you replaced your crank sensor, then the crank relearn procedure is required to complete the task.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
