jl stealthbox
:D I have just ordered the JL Audio center Console stealthbox & a Memphis 16-st3004 amp. I will get 75rms to my front Infinity components and 230rms to my sub. I'm going to run the factory rear speakers off the factory head unit. I can't wait to get my new goodies. Im having it installed but will try to get some pictures to post. I also think that I will sound deaden the floor and back wall at the same time.
Bert,
Congrats.  I definitely need a 4 channel amp.  You wont be able to hear your rear speakers at all!
What sub comes with that box?
75 watts will make those Kappas scream :D
:D The Stealthbox comes with the JL 10w3-D2. I really don't think I even need the rear speakers nobody ever sits back there. I guess it would be nice to have a little rear fill. I'll see how it sounds then go from there. Can't wait!!!!! :D
