Subwoofer Enclosure
mpr3369
I have a 2004 gmc sierra ext cab and I want to build a box for 2 12s, does anyone have some dimensions for a good box and some pics I could go by. Thanks Mike.
Are you located around any major metropolitan area?
I found it was easier to just go buy a box that was built for my truck. Probably cost me about $40 more than making one. The box for my '02 ex-cab was right around $100 if memory serves. It would hold two tens or two twelves.
