Hello All!
VeroStearty
Being involved in the Airline industry both for travel and as a hobbiest, this is my opinion:
Major Airlines rated with 1 being the best and so on:
1. Delta/Northwest
2. Continental
3. American
4. United
5. US Air/America West
Discount Carrier:
1. Frontier
2. Alaska
2. Jet Blue
3. Air Tran
99. Southworst (They fall at the VERY bottom of my list, I will not fly them PERIOD)
Best customer service I've had has been with Delta/Northwest, (both airlines, which are now basically Delta) Continental, and Frontier. Worst customer service I've ever had has been with Southwest.
What locations are you going to/from? or where will you be traveling the most?
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
