Dominator Ii Installation
I just recieved my Dominator II steps for my 2005 GMC 1500. I was looking at the directions...they don't appear to be difficult to install, but I don't like the fact they mount to the body and not the frame. Has anyone out there installed these, and if so do they seem securly mounted?
They work for me. I weigh 245 lbs and there is some flex since they mount to the rocker pannels.
None the less, they are good looking steps.
I have 'em, never had an issue. They mount in the same location the factory side bars do. I assume it's the same for your 05.
Did you have to drill into the pinch weld? I don't want to sound anal, but I woul much rather mount to the frame.
No, they went onto the pre-drilled holes for the factory steps. Not sure if that would be the same for the 05. If you don't have pre-drilled holes I can understand not wanting ti drill into the pinch seam. I'm gonna guess and say that most after market side steps use that same set up these days.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
