Gmt900 - Stainless Box Rails Or ?
Looking for what to get for the box rails of the truck...Don't want the stick on plastic caps, I currently have an under-rail bed liner and a Truxedo Lo Pro tonneau cover...
Was thinking stainless side rails, but only have seen the Putco ones, or the factory GM ones, which I have heard some have had problems with the plastics ends???
Any brand recommendations, and pictures?
What about just the chrome or black inserts for the stake pockets??
Thanks...
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
