2005 Gmc Rear Brakes
Just got done putting a set of rear brakes on dad's 2005 GMC 1500. They were drums. It went real easy. We took pictures after we took the drum off to show how everything went together. We didn't really need them. GM did their homework. The design was super simple. Only two spring, the shoes and the adjuster. We replaced everything (drums, shoes and spring kit) and that made life easy.
Theres nothing wrong with drums on the rear. The problem is most young people don't understand them. I grew up when vechiles had drums front and rear and no antilocking systems. The ones on my 05 work great. :smash:
http://www.classictrucks.com/tech/0911clt_...sics/index.html
Theres nothing wrong with drums on the rear. The problem is most young people don't understand them. I grew up when vechiles had drums front and rear and no antilocking systems. The ones on my 05 work great. :thumbs:
My last truck was a 1970 C10 with four drums. While it wasn't the stopper my '05 is it was good enough for what it was. That said I will never go back to the old tech after owning this truck.
I am kinda glad they aren't discs out back...I understand they had trouble with the 4 wheel discs.
My opinion as well.... :thumbs:
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
