2007 Silverado Lt - Plastic Fairing Under Bumper
charv66
That plastic fairing just under the front bumper reduces the ground clearance significantly and it often hits the ground. Is there any downside to removing it?
Not that I'm aware of. GM put it there to create better air flow but I saw no difference with it on or off. So if your looking for a little extra clearance, remove it. :eek:
Thanks.
I just got off the phone with dealer....he said it protects important compoments near the rad and tranny cooler?? and to leave it on? I have my doubts about that....
I drove around a whole winter with mine off...didn't affect anything when I ran into snow banks and stuff...except the font tag....that wrapped up around the bumper.
I thought it kinda looked mean when it was removed...
I have an 03 though....if you have an 07 classic it will look like mine did...not sure about the NBS
Removed mine last year...Not a problem and gives it a better look....
I can see a screw holding it down on both ends, are there any in between and if so how many? (I can't get under my truck at the moment too much snow!)
Should be held in with those stupid plastic push pins.
Got it off! It was held by four 10mm screws and clipped on in about 5 spots. Just pulled it off and got an extra 4" clearance on the front. Had a good luck underneath, as far as I could see it served no useful protection purpose. It may affect gas mileage but not much. Looks better too - I find. With that stupid piece on, my minivan had about the same amount of front clearance...
********Cough*****
USELESS WITHOUT PICS
:crazy::lol::D
Here is a quick blackberry snapshot.
Yeah...that's much better man, I really think they're just there to hit the concrete blocks at the end of parking spaces. Just to let you know you've gone far enough....
Other than that...its pretty much a useless piece of plastic.
I believe the facia is there to promote more air flow thru the rad by taking away air from going under the truck,
if someone else heard that chime in
The way the facia is angled, I can't see much airflow actually being deflected upwards.
I've heard that too, but again... didn't see any difference with it off. Since my truck isn't lifted, I left it on.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
