Looking For Mods
boyhonda5
Im looking for a complete exhaust for my truck (99 Chevy K1500, 3 door ext cab, 6.5ft bed, 4wd.
I have a complete cat-back exhaust that I took off my 2005 Ext. Cab when I upgraded. Is this what you're looking for or do you need the headers as well?
