Quick Question About Hid
On driver side for low beam, I mounted on the side of the fender, parallel to where the 2nd battery would go. On passenger side i mounted it between the radiator and headlight. If you look down next to your headlight, you will see the metal rad support and there is a perfect gap to mount it to the side of the bar. BTW, I used double sided tape. DO NOT USE 3M. I never have good luck with that, its never sticky enough. Scotch is pretty good.
For the fog lights, if you take out your grill, have one person under the truck and pass up the ballast. then mount it somewhere around the headlight.
ok thanks ill try that.
On the passenger side I put it on the radiator core support bracket in front of the airbox:
And on the drivers' side it's in basically the exact same spot but in front of where the second battery tray is.
Once everything is assembled, you basically can't see the harnesses/ballasts unless you know what you're looking for.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
