Turn Signal Mirrors
Actually you don't have to buy the whole housing.....Muth Mirrors
:jester: for that price i would rather look for some take offs, i just saw some on craiglist for like 230 around my area
LH
http://cgi.ebay.com/ebaymotors/08-TAHOE-LE...es#ht_500wt_956
RH
http://cgi.ebay.com/ebaymotors/2007-09-Che...s#ht_500wt_1182
and you can put your stock mirror caps (silver) onto these ones and your set ;)
this is just what I found in the first 30 seconds, im sure you can find some for a better price, but i'd definitely look around.
I just sold a set for $325.
To answer your question, yes the turn signal function will work as plug-n-play. However the power fold will not work unless you have the special door swith for that
  • 3 weeks later...
MUTH is wonderful, but you can get glass on ebay and then just make the harness using the MUTH site's posted instructions and save a fortune if you get the glass cheap enough.
Yes, and the door harness if your truck is not an LTZ or SLE model because the normal truck interiors have different door harnesses that have different connectors. The required switch will not plug into the harness of a non luxury interior and it comes unprogrammed new, so you have to talk the dealer into programming it.
