Tmaxx And Revo Bodies
Jubei69
lol, I forgot have a tmaxx 3.3 and revo in my garage. I need to find a GMC Sierra or Chevy Silverado body for them so I can have mini gas versions of my full size ride... :dunno:
I have a Silverado and an Escalade body for my HPI Savage. I am pretty sure Justin has one for his TMaxx...
Where did ya get the spare bodies Jennabear?
Sweet proline does have nbs' silverado body, i'll have to mod it to make it look like a gmc front...
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 182 Guests (See full list)
