Wanted: Blue Granite Parts
Hello folks, I am looking to get some blue granite metallic door handles four of them. I would also like mirror caps and the front bumper cover in the same color. I know its a long shot but figured I would give it a try. Thanks.
Looked on ebay I did not see any...It appeared that door handles were about $125 for a set...is that to much ?
I do relize that these are getting harder and harder to come by...
I think thats about an average price.. anything less obviously would be better. I've seen them for under $100 though.
Sounds fair to me, guess I will have to keep a look out on Ebay.
Yeah you'll just have to keep an eye out! It took me a couple months to find the mirror caps and door handles. Like said eBay is probably your best bet. I know there was someone on here who had a set of 4 handles. I dont know if they still have them!
