Part Number Questions
Ok i have a job coming up that I need to get the correct part numbers for. So before I head to the dealership for parts I want to know what I am asking for.
Project: Replace front diff seals
Parts Needed:
Updated seals for both sides
Bearings for both sides
Deflectors? both sides
I have been told to replace the "diff side bearing lock retainers"?
Also U-joints for the front shaft (might as well since its all going to be apart)
I have never done this before, but I feel pretty good about doing it since I am working down there I just plan to throw all the PM's at it. Anyone notice anything I am missing, or have any input?
I have searched the past posts and have not really found what I am looking for, once completed I can post pics for others to reference
Axle Seals....Part#15801507 - $16.75
Bearings;Inner LH & RH...Part#26041515 - $31.16 (Unless your unbolting the axle tube from the carrier you'll only need the one on the LH side)
Bearing;RH Axle tube housing....Part#26066885 - $33.45
Adjuster;Frt. Diff. Bearing (Incls. insert,sleeve & nut)...Part#12470318 - $51.46
There are no seal deflectors.
U-Joints;Frt driveshaft....Part#12479126 - $124.58
    MANGOAL
    MANGOAL
  • Who's Online   1 Member, 0 Anonymous, 482 Guests (See full list)
