Water Spots Inside Light Assembly
I had a leak in my taillight assembly that allowed little condensation inside. I removed the assembly, found the leak and resealed it. Now I notice a few small water spots on both the lens and the reflector. Is there a simple method for getting rid of those spots?
You can try spraying glass cleaner on a soft cloth and then fish the cloth inside through the bulb openings and wipe it around.
Thanks for the suggestion. The spots do wipe off easily when I can get to them. There are areas that can't be reached, no matter what you do.
I think I will experiment with some other plastic using a diluted dish detergent mixture, and maybe some other diluted liquids, and just slosh them around and drain. If it works then I will try it on the lens.
    Enduro73
    Enduro73
  • Who's Online   5 Members, 0 Anonymous, 777 Guests (See full list)
