2.5" Leveling Kit And Rear Block Kit
Im planning on installing either a Truxxx or Daystar 2.5" leveling spacer then Zone shocks. With this much level in the front Im expecting to need to put blocks in the back. What size would I most likely need? Any links to good priced ones would be awesome. Thanks.
Easiest thing to do is just measure your truck how it sits and add 2.5" to the front. That will give you a good idea how much you'll want to lift the rear. Depending on how tail high you want it - probably just need an inch or two tops. Cheap blocks - Zone, Suspension Connection, Top Gun, etc.
I've got the TRUXXX kit up front and the Readylift blocks out back. The TRUXX kit you can vary the lift by removing some of the stackable plates.
As for blocks go here Readylift Blocks They are for 2wd or 4wd, this link is for the 3" ones, that seem to equate to a 1" lift in the rear when installed from what I have read everywhere.
Did you put new shocks on the front?
I haven't put my kit in yet, I am waiting for the crappy weather to pass. But I don't plan on new shocks. Its just a spacer that goes on top, and another for the bottom.
Does the Truxxx kit come with shock spacers?
    btm
    btm
  • Who's Online   2 Members, 0 Anonymous, 1,067 Guests (See full list)
