Banks Ottomind Programmer
Anyone purchase yet? claims -> Flexible all-in-one programmer & scan tool. Delivers "power on demand" by removing factory's power delay. Displays a host of critical engine functions and provides "service technician" diagnostic capabilities.
I know blackbears tune offers the best performance but i would rather have a handheld tuner i can remove at anytime. i just want to get rid of the damn torque management
What's the cost? The Diablo Predator does the same, plus allows you to data-log and dial-in some critical parameters. It also supports tuning by a Diablo custom tuner. The Predator does *not* currently support transmission tuning, but a Vette servo swap (arguably) gives you some of that without tuning. Just another to consider...
From what I understand, BlackBearPerformance will be offering the EFI LIVE AutoCal as a handheld solution. It should be out soon. Check with Justin at BB or hopefully Jenna will chime in soon. But it should be available within the first quarter of this year.
