Front Seat Floor Console
I am looking at getting another Chevrolet Truck. I am looking at a 2006 or 2007 Silverado. I like the front seat floor Console (D07 Code) but cannot find a truck i like with one. Finding trucks all over without the console.
Is there an aftermarlet floor console that fits in there and looks good as the factory one?
Not handy enough to build my own.
Any help out there on where to go to get a console. Any suggestions?
Thanks
