2007 Nbs Silverado 1500 P/s Pump Not Covered Under Powertrain?
so I noticed the other day that my power steering pump is leaking, I called my gm dealer today and they said it is NOT covered under the 5yr/100k powertrain warranty............am I missing something or is this correct, anyone know? By the way I have 51k on my truck. Thanks!
Wasn't there a recall or Service bulletin on the power steering pumps leaking on the GMT-900? Maybe you can get help that way :)
No,It was on the steering racks,not the pumps,and it wasn't a recall,it was a service information bulletin.
Both the steering rack and pump would not be considered part of the powertrain,therefore neither one would be covered under the powertrain warranty.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
