Water Pump Weep
Hey Guys,
Ok so almost 2 years to the day my Water pump appears to be weeping out the weep hole.
See thread here where I changed it out:
http://www.gm-trucks.com/forums/index.php?...c=72209&hl=
However, now it's weeping again and oddly enough today, I only noticed it do it when the Block heater is plugged in. I'm going to leave the Block Heater unplugged for a week to see if it does again but, I'm pretty sure it's completely coincidental to the Heater being plugged in.
I'm surprised as heck that the water pump has failed after such a short life but, maybe it was a bad unit. It wasn't a true "GM" water pump it was a replacement one from Lordco.
Perhaps I should pony up and get the correct one from the dealer...
Anybody have any thoughts on this?
Evan
All my mechanic friends tell me to never buy a re-furbed pump or alternator or other crap, and to always get new. ??? I went thru 3 re-built autolite alternators once within 2 weeks on an old 89 Jeep Wrangler before I took it into my mechanic, all he did was take out the POS rebuilt and put in an a brand new AC/DELCO, never had a problem after that :crackup:
Guys, there is nothing wrong with rebuilt alternators or water pumps. It all depends who rebuilds them and how. A properly rebuilt alternator will have all its internal parts replaced, all they reuse is the outer housing. This what you buy for example from a Nissan or Mazda dealer. On the other hand, one from Autozone or Advance Discount will have only the front bearing and the voltage regulator replaced, and that's it. So if something else like diodes or the stator windings fails, the alternator will go bad in a very short time.
The same goes for waterpumps. If the housing is in good shape, all they need to replace is the bearing, seal, and the impeller.
However, cheap rebuild shops in Mexico may not replace anything but the seal, and maybe even press it in wrong. And that is the type of rebuilt water pump that comes in a nice shiny box at Autozone for $ 9.95. Discount auto parts stores typically buy rebuilt parts from the lowest bidder and abandon them when they have too many returns. It is ultimately the customer that gets frustrated with crappy parts that have a "lifetime" of a few weeks.
My water pump is going out on my '96, and I decided to go with a new True-Flow pump from Napa, they have a lifetime warranty on them, and appear to be pretty good quality, and the salesman I talked to and know personally said that they have had no trouble with them, and that's what he reccomended
