No Dash Lights Or 4x4 Selector Lights
runnerbeep
Truck is a 2006 2500 crew cab 4x4 duramax. I shorted out a light in my over head console while installing my radar detector.Found the fuses I blew and replaced,cured that problem.Now I have no dash lights and no 4x4 indicator lights.When I move the dimmer dial the lights on the radio will dim and get bright.Have checked all fuses I can find. Any advice would be appreciated.
bump
what?
i had similar problems but i was just pissing around in my truck. so you did check all your fuses iam correct? Just thought i would ask cuase when i did that to my truck i checked the fuses that were more then likely would run my dash lights and they worked just fine. more digging around and for my dash light was labeled unmarked in my fuse panel and it wasn't near those other ones.
All your connections going to that light still fine? like they arnt grounding out somewhere and constantly blows that fuse?
I even went to thye exterme of pulling every fuse in cab and under hood and visually check,there all good.Whatever common between my dash lights and 4x4 indicator is where I will
find my problem,but driven me nuts looking for it.Any other ideas would be great.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
