New Steering Wheel?
hey guys grant has a beautiful replacement steering wheel with all the buttons and everything. my truck having 155,000 miles on an 06 u can only imagine the wheel is alittle worn is there any special methods in removing the wheel? and tricks? and how hard is it? thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
