Cylinder Identification Confirmation (no. 2)
I've searched o-plenty without finding an answer.
I have a 1996 Suburban with the 454 (7.4L) motor. My understanding is that cyllinder No. 2 is on the passenger side, closests to the radiator. Is this correct?
Thanks in advance.
you would be correct.. # 1 is the front driver side, and the go back and forth (drivers side to pass side), front to back..
Yep, Standing at front of truck looking at engine. Right Side 1, 3, 5, 7
Left Pass side 2, 4, 6, 8
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
