Ac Light Flash
hotrod71
Hello,
I just purchased a 2002 Yukon Denali and noticed last night when checking everything out that the AC compressor was not kicking on in either the defrost or AC setting on the control unit... It was snowing and cold when i test drove the vehicle and did not think to test the AC then... I put my gauges on teh system and it seems to have plenty of 134a.... Tryed by-passing the presure cycling switch on the accumulator and still it does not kick on... I did notice that when selected the AC light on the control unit flashes three times before going out... Any suggestions?
If the outdoor temp is too low, the compressor will not engage. At least this is the way it used to be .... double check that info.
Thank you i found some other posts on that issue also
if the fans not on the ac will not run either...mine blinks then shut offs if i hit the button without the fan spinning
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
