4l60e Filter
Gentlemen,
Does anyone have any clever ideas on how to remove that rotten seal in the valve body where the filter inserts on the 4l60e transmission? I love chevy but that system seems to be pi-- poor.
Ken
The little tool that looks like the one the dentist uses to make you cry! I dont know whats its called but when I see one I keep my mouth closed
I'm getting ready to change my filter/fluid. Does the filter just pull straight out? Then the seal gets changed? I've got over 60,000 miles on this filter so I figured it's time to get it done.
it's a rotten brass thing with a rubber seal inside it that presses into the valve body. No o rings used. There is a new one in the filter kit, getting the old one out is a bitch.
Ken
I don't mean to thread-jack, but, how do I tell if I have the "deep-pan" on my transmission? Can I tell just by looking at it? I have the 4L60E as well.
You can tell by looking at it. The deep pans have a portion that drops down, rather than being flat straight across. The shallower end is above the y-pipe (a.k.a. intermediate pipe) of your exhaust.
Pan has a step in it. Hard to explain but I have looked a quite a many I can visually see the difference. Now that I have had both shallow and deep pans on a couple I have serviced in the same weekend.
Also, A GOOD stiff dental pick and just keep away from the aluminum in the valve body you DO NOT want to mess it up (I have used a coping saw blade before to simply cut it enough to weaken the metal and bent it and pulled it out with pliers if its a pain the the A$$). Wipe the port out then apply some ATF to the port and the seal bump seal in with a socket.
Jbo
:P
That Seal is a PITA!!
But with the right tools and the time it will come out....also besure its seated all the way up there before you put the filter on
Best of luck...
Cool, thank you. But, I think I have to return the filter kit I just bought, as the guy told me it was for the shallow pan tranny and now I think I have the deep pan. :P
When in doubt take them both home, you can always take one back.... It makes things go easier when you pull the pan off....
Jbo
