Next Couple Of Mods...
So I thought I'd post what I plan on doing as far as my next couple of mods go to just get some idea from some of yall or some feedback. I think my very next mod that I will do will be exhaust. I've been looking at this for a long time a really trying to decide on what I want. Considering there aren't many videos of 4.8's with exhaust (or at least I couldn't find many) I based my decision off of what I could find and what was said in other threads. I'm 99% sure I will go with the Corsa Sport with the dual out. LINK. Here are the video's that helped me decide.
Vid 1,
Now with exhaust I'm also thinking of getting some JBA Headers. This is something I know nothing about. So if anyone can help me, what exactly do new headers help with and what do they do? The only reason I would get some is because of this video,
. I think compared to the second video it sounds much better. So what would be some recommendations as far as headers go?? I just want better sound but don't want to be obnoxiously loud. Want a growl to go with the look of my truck.
After those mods I plan on improving the aesthetics of my truck some more. I really like the Grillcraft MX Grille but there are times that I find myself really loving my front end the way it is. I'll also be swapping steering wheels for one with radio controls, replacing my 4 cluster gauge with the 6 cluster gauge, and way down the line a new new navigation system with viper alarm/2 way start.
Gear change may happen somewhere in there as well as a vette servo. But I don't feel I need that right now or at all maybe.
I'm sure I forgot something in there and along the way plans will change and mods will be added. I just got in colormatched door handles and mirror covers so those will hopefully go on this weekend or soon.
Sooo I guess after typing all that let me know what you guys think as far as everything. Good ideas? Bad ideas? Help me out with the header idea?
THANKS!
I think you will be very happy with the exhaust. I don't know about the headers, unless they gain low end torque I wouldn't pay the money for them.
The steering wheel is easy to swap out and I would do it soon, you will use it all the time. I would replace your cluster for the Z71 appearance pkg.
http://www.usspeedo.com/view.php?id=319
I would do the vette servo soon too. You can't beat it for 20 bucks and its easy to do. The grille would look good on your truck, but I think you should get fog lights first.
Thanks man. That's the speedo I would put in. Love the carbon fiber. And I guess I forgot to put the fog lights at the top of my list. That is def something I will be doing.
Same here... Fog lights are on my wish-list along with about 500000000000 other things for this summer :P
Nice plan, I had no idea you were running a 4.8L in your truck.
Yep it's a small one. Which is cool with me, I don't tow or haul, I don't have a 4x4 and don't go offroading (sometimes wish I did though), and don't plan on needing a bigger engine.
I also have like the 3.23 gears.. I think... which I know theres alot of threads out there about this but that's something else I don't understand. Should I regear or not? I figure it's not necessary but just one of those it would be nice kind of things.
I'm not sure what kind of headers you're looking at from JBA, but here's a basic idea of what headers do... Headers are there to basically balance and optimize exhaust flow from the engine. They are there to open up the flow right from the motor. In the picture below (borrowed from Dan's 6.0 swap in the pickle) you can see some longtube headers compared to stock manifolds. Opinions on headers are like opinions on anything else; some love 'em, some don't think they do anything. The next argument comes with long vs. short tubes. The general consensus seems to be that the gains from shorties aren't worth the cost. However, longtube headers have been known to help low end power torque.
Your gearing issue: 3.23's aren't meant for towing. (Don't get me wrong, your truck is still a truck and can tow quite a bit). They're meant to turn low RPM's at cruising speeds. The numbers you hear getting thrown around (3.23, 3.73, 4.10, 4.88, etc...) are approximations for the number of times the driveshaft will spin to make the wheels turn one revolution. More revolutions = more mechanical advantage. Changing gears can increase the towing capabilities, "out of the hole" performance, and gain back performance that is lost with bigger tires. If you don't tow, haul, or race often, I'd say you'd be happiest with your current gear set-up. Saving gas is :P
from actual experience with a 4.8L:
I had a 2003 with the 4.8L
The truck had Gibson Shorty Headers, Corsa Touring Catback, and was regeared.... so I might be able to give you a good idea of what you are looking at.
The Gibson Shorty Headers were a waste of time and money. A stock internal 4.8L can not push enough air to benefit. The same goes for Long Tube headers on a 4.8L, long tubes would in fact lower your torque output on the 4.8L which is the motor that needs it the most. I've installed long tubes on a 6.0L, but that 6.0L also had special heads and an nice lopey cam helping it pump some air.
I had the Corsa Touring Catback - you can't go wrong with a Corsa, they are pricey but there's a reason for the price. I don't have extensive experience with the Sport version, I had the Touring with side outlet twin Pro 4.0 tip. The touring was quiet at idle (similar to stock) and just barely louder than stock when cruising on the highway, however it sounded mean when you put your foot on the go pedal.
My old truck also went through a gear swap. I had an open differential 3.42 setup from the factory. I swapped in a Eaton LSD with 3.73's. I lost no gas mileage in town and gained take off speed. I lost about 1-1.5 mpg on the highway, but when towing the truck was much more at home.
Oh yeah, gauge cluster swaps (even though it was a GMT-800):
I swapped my stock gauge cluster for the Denali version, which has a subtle difference in appearance and added the transmission cooler.
That brings me to the next thing: if your oversized tires and the 4L60e you really should add a transmission cooler, you may not be towing but the transmission is laboring everyday turning those tires.
As for the grille, that's up to personal preference, on my old truck I had a billet insert that looked great, on my current truck I like the stock GMC SLT chrome setup and I'll leave it alone.
I see that you are local to me, if you have any questions, need to talk in person or need any assistance with your mods let me know.
I'm a minimalist when it comes to mods so I would definitely go Fog Lights first then exhaust. Unless you have money to burn I wouldn't get headers, price to gain ratio is not that high. I can't decide if that grill would be worth it or not. I find grills look really good in internet ads and not so much in person. I've been thinking of doing my exhaust too, I just want to swap the muffler for something with a LITTLE bit more growl and a stainless tip. I don't even want duals, just a single. Modding your truck can be addictive, remember to K.I.S.S. :P
P.S. I live in B.R. think I saw your truck the other day, I was checkin it out :P
Your gearing issue: 3.23's aren't meant for towing. (Don't get me wrong, your truck is still a truck and can tow quite a bit). They're meant to turn low RPM's at cruising speeds. The numbers you hear getting thrown around (3.23, 3.73, 4.10, 4.88, etc...) are approximations for the number of times the driveshaft will spin to make the wheels turn one revolution. More revolutions = more mechanical advantage. Changing gears can increase the towing capabilities, "out of the hole" performance, and gain back performance that is lost with bigger tires. If you don't tow, haul, or race often, I'd say you'd be happiest with your current gear set-up. Saving gas is :lol:
Thanks alot guys for all of the info. Now knowing that headers more than likely won't do much except possibly enhance sound I will not spend that kind of money on that. I didn't think I needed to regear and with yall lending some advice I think I'll leave that the way it is too. Main reason I'm going with corsa is because of its great reputation and quality. Everyone here who owns one loves it and I think I will too.
Nick thanks alot man. I'll let you know if I ever need anything. There are alot of users on here from Louisiana, mainly south LA. It would be cool to set up some kind of meet or something.
I'm a minimalist when it comes to mods so I would definitely go Fog Lights first then exhaust. Unless you have money to burn I wouldn't get headers, price to gain ratio is not that high. I can't decide if that grill would be worth it or not. I find grills look really good in internet ads and not so much in person. I've been thinking of doing my exhaust too, I just want to swap the muffler for something with a LITTLE bit more growl and a stainless tip. I don't even want duals, just a single. Modding your truck can be addictive, remember to K.I.S.S. :mad:
P.S. I live in B.R. think I saw your truck the other day, I was checkin it out :D
Thanks alot man. Where did you see it? Everytime I see another GM on the road with some sort of customization I wonder if they are a member on here. I'll keep an eye out for yours. :cheers:
If you do get new gauges get new needles too. The stock needles are ugly and I love my new needles.
I have these I bought from someone but haven't installed them yet
http://usspeedo.com/view.php?id=55
Idk how I feel about them. I guess I'll wait and see
I have some rst ones in mine. If you decide to sell yours let me know I like switching stuff up lol
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
