Chev 5.3 Coolant Leak In Oil
jukebox
Hello, I have a 2005 Chev Silverado with a minor coolant leak.
Tested system to 21 PSI with no leaks anywhere.
Used about 1 gal over 1 month.
Changed Oil and found Jelly Like Sludge in Oil pan.
Drained oil and sludge and installed new oil.
Truck has 85k miles, Oil changes done evey 3500 miles and well maintained.
Is there coolant running through intake manifold, I heard this could be cause or
Head Gasket, other.
Do you have any history on this problem ? I see I am not alone with this problem.
Thank you, Charles e-mail: [email protected]
There's a TSB out for Castech heads that crack, Do a search on here for Castech and you'll come up with more info on this subject than you care to read.
TSB means technical service bulletin....in case you were wondering.
Head Gasket, other.
tHANKS , i AM FINDING THIS OUT ALREADY
[/size]
Head Gasket, other.
Head Gasket, other.
This may give you a place to look before you tear down further
Last year my 1999 gmc 4.8l 250,000 km had all the issues with the valve noisy lifters, loss of coolant with no visible sign of leaks on outside of engine.
I checked to see if I had the castec heads and did not.
Another thing I found in regards determining if you have antifreeze in you oil is your oil will not always be ' milky' on the oil dipstick to confirm that antifreeze has mixed with the oil, antifreeze does not like to mix with oil. You have to drop your oil and if it comes out kind of chunky or blobs, you have antifreeze in the oil, it will end up on the bottom of your drain pan.
I found the problem when I pulled the intake manifold off, THE TOP ROW OF BOLTS ABOVE PUSHROD GALLERIES, (11mm, not the main head bolts) ON THE LEFT HEAD HAD LOST TORQUE and subseqently antifreeze was able enter the oil pan via the valve pushrod galleries, there was evidence of corrosion, etc on the pushrods, aft lifter area.
At this point I was 90% sure I found the leak but decided to change the head gaskets, when they were pulled I found no evidence of leakage around the head gaskets gaskets.
So what I suggest, pull your intake manifold off, (only way to get at the smaller 11mm? bolts) check torque, if loose retorque, put intake back on (new gasket), if not and no sign of corrosion etc in pushrod galleries continue on with changing out head gaskets. If you do this it should take, 2-3 hrs versus 4-8 hr for a head gasket change depending on your experience.
If you are looking for a complicated explanation for this problem there is not one, that was all it is. Let us know what you find, Good luck and pm me if you
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
