I am about to perform my 2nd oil change tomm, The dealer performed the first one at 2500 miles free of charge, Now i am going to be doing this myself Here is the question..... What oil filter should I use? Is the Amsoil filter worth the cost or should I just stick with the GM filter?
Thanks for the help in advance.. Also I think I am going to run the Valvoline full Syn.. Unless you guys change my mind... :pimp::dunno:
I would recommend Mobil 1 myself, it's what I use. I know some other full synthetics out there boast "better wear protection than Mobil 1 based on the (insert test number) four ball wear test". The ball wear test is based on extreme pressure wear, such as would occour in your differential, NOT in your engine. So if you were to use motor oil in your diff, one: you'd be an idiot, and two: (insert brand) would do better.
But I digress, in my opinion Mobil 1 engine oil is the better brand out there. I personally run a Mobil filter and 6k between oil changes. If you don't feel like dropping the money on a Mobil filter, or plan on changing your oil every 3-4k, Wix is a great brand. The parts store I work at sells Wix, and I know the Napa gold filters are made by Wix (but so is Bumper to Bumper's 'Parts Master' house brand filters).
Mobil 1 full synthetic for my vehicles, along with a Mobil 1 oil filter. The price of full synthetic usually deters people from using it but I have found that purchasing 5W-30W from WalMart is by far the cheapest ($22 IIRC!). Plus the filter it comes out to a little over $30 and your lookin at another oil change at least 5000 miles if not more using the OLM (Oil Life Moniter).
Mobil 1 5W-30 full synthetic and Mobil 1 filters here, along with a half can of Seafoam in the oil with the engine running for ~20 minutes before each oil change.
Mobil 1 full synthetic here, but I use the stock AC Delco filters. I see no reason to spend the extra money on the Mobil 1 filter over the Delco. The Delco is just as good. Now, I will say however, that when Advance Auto runs a special on Mobil 1 that includes a Mobil 1 filter, I do purchase the package and use the filter because it's cheap.
Since everyone is Mobil 1 I will go ahead and say it, I would run the Amsoil filter and Amsoil 5w-30. I have personally seen how Amsoil protects differentials and engines in race cars that I have built and I will never use another product.
No one mentioned K&N Oil Filters? I use to work at a dealership washing cars back in the day and always seen the mechanics put Mobil 1 full synthetic and K&N Oil Filters on all their own rides. They refused to use the basic OIL from the dealership.
I usually pick up Mobil 1 oil from walmart for the 22 bucks... and a 10 buck K&N oil filter from Advanced auto parts change the oil myself for the same cost for a mechanic to put in a cheap oil filter and oil.
All the tests showing some brand is better than Mobil 1 have marginal gains. Amsoil has a set of tests on their site that they did and as I said, the gains are so minute it's not even worth the trouble of trying to buy it. Funny how they couldn't cheat on their own tests to make it look like it's at least 1% better than Mobil 1.
Mobil 1 is good oil no doubt, but I quit using it several years ago when I noticed that the valve train noise (lifters?) was reduced with different motor oils. Sounds crazy I know, but try some Castrol Syntec (preferrably 0W-30) or Pennzoil Platinum or Amsoil XL and I bet you'll notice your engine runs quieter/smoother than with the Mobil 1.
But your question was about filters... In my opinion, Napa Gold, Wix, and Purolator PureOne are the best sub-$10 filters. Mobil 1 filters are great if you don't mind spending the money. AC Delcos are OK as long as you don't end up with the newer (read 'cheaper') E-Core design. Stay away from Frams at all costs.
Many have recommended buying the oil at walmart - good call, walmart has good prices on the 5-qt jugs... but it is getting harder to find a good filter for a GM at Walmart. Just try to find a Fram or SuperTech #3675 (for a 1999-2002 5.3) - thats right they don't make them anymore - they switched to the shorter, cheaper filters to save shelf space and shipping costs.
No, unless you're gonna spring for a Mobil 1 filter, stick with something made by Wix (Wix or Napa) or Purolator (Purolator, Bosch, ProLine, MicroGard). Although I think MicroGard discontinued their 3675 as well.
As for you "ac delco is what was original so thats what you should use" guys, I agree on most parts - but not on oil filters. The quality of AC Delco filters has diminished significantly IMO. I used Delcos a lot back in the day. No more for me.
I don't think you will notice any valve train noise difference with another brand of oil. A 2003 Chevy versus a 2008-2010 Chevy engine is a pretty significant difference. I have used all the oils you speak of and I noticed NO difference whatsoever in noise. My engine runs as smooth as silk with Mobil 1.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 2,016 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
