08 Nbs Yukon Fog Lights Help
i have a sle yukon but it did not come with fog lights where can i buy and how can i install them please help
the part number for the factory accessory kit is listed at $225.00 19157652
its very easy. that accessory kit that the post above listed comes with both fog lights the harness from the fog lights to the fuse box and a new switch assembly to replace the existing one inside your truck. the caps that cover the fog light holes just pop out then then new fog lights pop right in and run the wire up to the fuse box. install the wire leads and replace the switch. the kit comes with instructions. it takes maybe 30 minutes to do.
