Wind Noise?
yesterday i bought a 2005 2500HD and when im driving there is a loud noise coming from the driver side window as if the window is open, yet it is up the full way (crank windows). when i close my door you can also hear something in the door is loose, i dont know if this is my problem. has anyone had a similar problem or know the solution?
  • 3 weeks later...
If this is an ext. cab, make sure the rear doors are closed right. In some trucks you have to slam the rear doors. :thumbs:
this ^^ i have that issue too when my girl doesnt close my rear door tight
  • 1 month later...
Since you say it's coming from the driver's window and not any other window or door- check to make sure that the felt lip at the bottom of the window, right behind the edge of your door panel is still intact or in good condition. But I'd almost bet that your doors weatherstripping is dried out and needs to be treated. Try running some dielectric grease on the weather stripping, letting it seat for a few minutes before wiping if off with a rag. That seemed to help with my wind noise issues. Also make sure that the noise your hearing isn't coming from the back driverside window if it's a extended cab. Treat the same way. Let us know once you find the problem-
