Hid Conversion
So I want to do an HID Conversion on my 97 Sierra. Do i have to install 2 seperate kits (4 ballasts), 2 for my low beam 9006's, and 2 for my high beam 9005's?
You will need 2 kits. 4 ballasts in total. Make sure you get the relay that keeps you low beams on when you put your highs on, if you dont you will be in the dark for 3 sec or so when going to high beams on hwy. also get the upgaded wiring haness or you may get some issues with only one bulb turning on sometimes. good luck with your install
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
