Gmt 900 Dl3 Swithes
I purchased theses switches a few months ago to upgrade my mirrors, but my tuck has different connectors. They were removed from a 08 Silverado CC with less than 10 miles on them. They look new, no scratches or wear marks. $130 for the pair shipped!
These will work on an LTZ as well. You need to reuse your old bezels. If you would like me to send a picture of the switches removed from the bezels to check for fit, please let me know. I would encourage this to make sure...
I purchased theses switches a few months ago upgrade my mirrors, but my tuck has different connectors. They were removed from a 08 Silverado CC with less than 10 miles on them. They look new, no scratches or wear marks. $130 for the pair shipped!
I'll take them if my connectors look like the ones in the pic. I am looking to upgrade to the DL3 mirrors, but need to see what connectors I have under those panels on mine as well.
What year is your truck ?
My truck is an 08, I do not think the year matters, it is what options the truck is wired for....
Hmmm, I'll have to check mine then, as mine did not come with the DL3 mirrors, and I wanted to add them. I may have the same problem you did. I mainly want the turn signal feature, but if I can get the auto dimming and parking tilt, that would be a plus
If you have the 08 true truck interior then you do not have the connectors for them. in 07 / 08 only the LTZ interior had them
Actually, that is not entirely true! These came from a true truck....
Yes, that became an option in 09. Never seen that on an 08 until now. interesting
A quick and easy way to tell if your truck is wired for DL3's is to remove the the fuse panel cover at the drivers side, look at the fuse panel. The upper left connector goes to the door, it should be Lt gray. On the top row of connector pins count three over from the left, pin a5, there should be a pink wire (color???). Next, on the next or bottom row. look at the first pin from the left, pin b7, there should be a a gray wire (color???). These are the wire for the auto dim control that comes from the isrvm.
Also, if you want to check for turns, which most vehicles are wired for, same connector, pin b2, bottom row, six from left or two from right, wire is lt. blue w/white stripe (color???).
This is easier than pulling your door panels, so if you have the auto dim wired, then I would pull the panels to double check..
$75 ? Let me know.
Sorry for the delay....How about $100 shipped, as long as you live in the US....
$75 ? Let me know.
Do you know if these will fit in my SLT/LTZ woodgrain trim door panels?
They should, you will have to use your existing bezel and remove the black bezels on mine (3 screws). If you are that interested I can remove the bezel and post a picture?
$75 ? Let me know.
$75 ? Let me know.
Let me check the panel on my Extended Cab when I get home. I don't think it has the rear window lockout button. Not sure if that will make the trim different or not. Otherwise, I'm interested.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 488 Guests (See full list)
