Chevy Silverado 1500 Tpms Issue
SparkySparks
Hello, I have a 2008 Chevy Silverado 1500 Extended Cab with the 5.3L V8 (Non-Flex Fuel) motor. I have had the truck for going on two years now. The truck has about 16,000 miles on it and had the factory tires replaced at 9,000 miles due to a bad alignment that destroyed the tires, this was about eight months ago. I noticed a few times this winter that the "Check Tire Monitoring System" message would come on from time to time. It did not come on during short drives and would go away after the truck had be shut off for a while. It is continuing to give this message. I recently had my tires rotated and they could not get two of the sensors to reset so I had to take it to the Dealership. The dealer was able to reset all four sensors and said everything was fine. I continue to have this issue if I drive the truck for more then 20 minutes. Could the sensors be going bad already or is it something else other then the sensors. If I need to take it back to the dealer should I wait until the warning comes back and take it to them with it flashing?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
