2002 4.8 Misfire On Cyl 7
I had the service engine light flash at me a couple times over the last couple days. Diag said misfire on cyl 7.
Service light flashed then stayed on for an hour and has now turned off.
What process should I follow after checking the plug wires and coil?
Swap the coils and see if the misfire moves...if it does thats the problem...same with plug wires.
than you will change out the plugs
Always remember..there are 3 items needed to run a 4-stroke engine...
spark, fuel, compression
Swap coils. see where the misfire goes
check plug, gap if necessary
swap injector to different cylinder if you have to
if all else fails, do a compression test.
Thanks guys will do the swapping. Anything to the light coming for a time then shutting off? We are talking days without a light, then stays on for a half day then off again.
    ar0517
    ar0517
  • Who's Online   5 Members, 2 Anonymous, 468 Guests (See full list)
