Electrical Issue
toppjimmy
I have a 1991 suburban, today I was parked and letting the ac run while my wife was shopping, I had bothfront and rear going. When I was leaving I put my foot on the brakes, the brake light came on, the ac units stopped working, and the power windows wouldnt roll down, the fuses were fine I did change the 30 amp relays though. What is going on.Also the speedometer stopped working........
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
