Back Seat Lift Kit
hi everyone , so i was lookin underneath my 09 ltz ext cab and was wondering if i was to make a 1 or 1 1/2 inch spacer and use longer bolts for where the seat supports or bolted to the body of the truck, would it work? prtoblems with strength or are the bolt accesable? also are there any supports behind the seat that i would have to mess with? i want to be able to fit a deep subwoofer under the seats so please respond back with any input on what i should or could do please
thanks you
thanks you
+ on this, good idea, i have 15's that are for sell because cant fit them in, I need more room... Any input would be really helpfull!!
ya im just gonna throw my alpine type-r in! the idea just came to me tonight as i was cleaning the truck! i defenitly think i could try it ,, might this sunday and see how things go but please someone give me some helpp??
Seems like it could work... I wonder if it will mess up the folding ability of the seat? Seems like you would have to mess around both the lower bracket where there seatbelts bolt in as well as something behind the seat. I haven't pulled mine apart to see what is back there, so good luck.
i fit a pair of memphis c3 12s under my 07 crew cab, there's a custom box, but the mounting depth wasn't big enough so i had to cut out the back and make it a little deeper, the seat is a little less comfortable now cause the box pushes up on it, but it's not bad.
Should be fine, probably will hamper the folding as one mentioned, but if you have subs underneath, whats the pt of folding?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
