Belltech 34324 2"-3" Lowering Kit 200 Up W/ Autoride
I have a VERY SLIGHTLY USED Belltech drop kit. I had it on my 05 Denali for about three weeks. It will fit 2000 and up GM trucks and SUV's with Autoride suspension. For more info go to www.belltech.com and search the part number 34324. It also fits 07 up trucks as well.
  • 1 month later...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
