1997 Chevy/gmc Factory Service Manuals
1997 Chevy/GMC Factory Service Manuals, good condition. $60.00 shipped to USA, $75.00 to Mexico and Canada(USPS Flat Rate) Paypal for payment. Thanks. Randypost-44855-1272378818_thumb.jpg
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
