I am from NW indiana
Anyone else?
Anyone?  Dont be embarrassed  :D
Maybe i need to put a gm-trucks.com sticker on my truck to advertise??? Someone send me one!
Hey thats cool.  Finally I am not alone.  What city are you from?
Im from Hammond.  About 35 mins from chicago.  Right off I80/94
I see all kinds of chevy/gmc trucks driving down US41 when i am at work.  I need to get my gmtc sticker and start advertising
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
