Driver Side Headlights Out!
woodruff112
i have aftermarker headlgihts in my truck and i was trying to put hids in. anyways the light after i put the hids on wont come on now.. is there a fuse for the high and low beams on my 09? is there a fuse for each one? help plesase..
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
